<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-camshaft-lobe-lift-specifications-547.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Camshaft Lobe Lift Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-camshaft-lobe-lift-specifications-547.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Power Steering Fluid Cooler</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</guid>
										<title>1992 - 1996 Corvette:  Service Bulletin:  Oil Leaks Between Intake Manifold and Engine Block</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Noisy/Fraying Accessory Drive Belt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</guid>
										<title>1995 Corvette: Recall: Distributor Vacuum Vent Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</link>
