<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-lt4-recall-rocker-arm-attaching-pin-not-fully-seated-516.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</guid>
										<title>1988 -1996 Corvette : Visual Differences Between Production Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</guid>
										<title>1996 Corvette: Engine Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</guid>
										<title>1992 - 1996 Corvette: Service Bulletin: Engine Miss/Poor Driveability Symptoms</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
