<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-seat-adjuster-excessive-movement-511.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</guid>
										<title>1984 - 1990 Corvette: Service Bulletin: Service Part For Seat Cushion Retaining Wire</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</guid>
										<title>1992 Corvette: Recall: Instrument Panel/Left Hand Lower Trim/Brake Pedal Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</guid>
										<title>1990 - 1996 Corvette: Inner Door Panel Screw Locations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Improved Access to Inboard Seat Belt Buckle / New Extender</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</guid>
										<title>1988 Corvette: Service Bulletin: 1988 Anniversary Model: Discolored Door Armrest</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-dealer-installed-anchor-for-child-seat-with-top-strap-anchor-installation-945.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Dealer Installed Anchor for Child Seat with Top Strap Anchor Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-dealer-installed-anchor-for-child-seat-with-top-strap-anchor-installation-945.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</guid>
										<title>Technical Article:  Inflatable Lumbar Seat Repair on C4 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</link>
