<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</guid>
										<title>1992 Corvette: Recall: Instrument Panel/Left Hand Lower Trim/Brake Pedal Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Improved Access to Inboard Seat Belt Buckle / New Extender</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</guid>
										<title>1994 - 1996 Corvette:  Service Bulletin:  Door Trim Arm Rest Lid Hard to Open or Close, Hinge Binding (Replace Hinge)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</guid>
										<title>Technical Article:  Inflatable Lumbar Seat Repair on C4 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1991-corvette-recall-left-right-side-safety-belt-retractor-replacement-508.html</guid>
										<title>1984 - 1991 Corvette: Recall: Left &amp; Right Side Safety Belt Retractor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1991-corvette-recall-left-right-side-safety-belt-retractor-replacement-508.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</guid>
										<title>1984 - 1990 Corvette: Service Bulletin: Service Part For Seat Cushion Retaining Wire</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-sun-visor-repair-tips-149.html</guid>
										<title>1984 - 1996 Corvette: Sun Visor Repair Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-sun-visor-repair-tips-149.html</link>
