										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</guid>
										<title>1991 Corvette: Service Bulletin: Information / Installation of Underhood / Courtesy Lamp</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</guid>
										<title>1990 Corvette: Service Manual Update: SEC. 6D4 Spark Plug Coding Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1990-corvette-service-bulletin-loose-carpet-on-side-wall-trim-pads-repair-procedure-683.html</guid>
										<title>1980 - 1990 Corvette: Service Bulletin: Loose Carpet on Side Wall Trim Pads (Repair Procedure)</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</guid>
										<title>1984 Corvette: Recall: Positive Battery Cable Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-ecm-codes-579.html</guid>
										<title>1985 - 1991 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-ecm-codes-579.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
