										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Power Antenna Will Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</guid>
										<title>1990 Corvette: Service Bulletin: Radio May Lose Some Functions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</guid>
										<title>1990 Corvette: Service Bulletin: Replacement of Isolation Diodes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</guid>
										<title>1990 Corvette: Recall: Product Campaign 90C07 Instrument Panel Wire Abrasion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</guid>
										<title>1992 - 1993 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</guid>
										<title>1990 Corvette: Service Bulletin: Tech 1 Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
