<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</guid>
										<title>1984 - 1990 Corvette: Service Bulletin: Service Part For Seat Cushion Retaining Wire</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-underhood-lamps-inoperative-or-staying-on-581.html</guid>
										<title>1984 - 1990 Corvette: Service Bulletin: Underhood Lamps Inoperative or Staying On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-underhood-lamps-inoperative-or-staying-on-581.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</guid>
										<title>1990 Corvette: Service Bulletin: Replacement of Isolation Diodes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Generator Noise (Moan) at Idle with Air Conditioning On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Improved Access to Inboard Seat Belt Buckle / New Extender</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</guid>
										<title>1984 - 1989 Corvette: Digital Dash Cluster Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-v-a-t-key-replacement-575.html</guid>
										<title>1986 Corvette: Service Bulletin: V.A.T. Key Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-v-a-t-key-replacement-575.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
