<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1967-corvette-delco-remy-service-bulletin-ignition-systems-940.html</guid>
										<title>1964 - 1967 Corvette:  Delco-Remy Service Bulletin:  Ignition Systems</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</guid>
										<title>1955 - 1964 Corvette:  Chevrolet PartsMart:  Bulb and Fuse Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Turn Signal Switch - Failure to Cancel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-bulletin-keys-for-1967-models-126.html</guid>
										<title>1967 Corvette: Service Bulletin: Keys for 1967 Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-bulletin-keys-for-1967-models-126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</guid>
										<title>1967 Corvette:  Chevrolet PartsMart:  Fusible Links</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</guid>
										<title>1964 Corvette:  Service News:  Servicing the Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-power-windows-special-policy-992.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Power Windows - Special Policy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-power-windows-special-policy-992.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</guid>
										<title>1963 Corvette:  Delco Service Bulletins:  Delco Radio Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-news-corvette-power-antenna-replacement-965.html</guid>
										<title>1965 - 1966 Corvette:  Service News:  Corvette Power Antenna Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-news-corvette-power-antenna-replacement-965.html</link>
