<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-roof-panel-adjustment-procedures-661.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Roof Panel Adjustment Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-roof-panel-adjustment-procedures-661.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Improved Access to Inboard Seat Belt Buckle / New Extender</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</guid>
										<title>1990 Corvette: Service Bulletin: Competition Yellow Paint Comments About Color Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1993-corvette-service-bulletin-rear-lift-window-hard-to-open-hinge-loose-to-glass-669.html</guid>
										<title>1984 - 1993 Corvette: Service Bulletin: Rear Lift Window Hard to Open/Hinge Loose to Glass</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1993-corvette-service-bulletin-rear-lift-window-hard-to-open-hinge-loose-to-glass-669.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</guid>
										<title>1990 - 1996 Corvette: Inner Door Panel Screw Locations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</guid>
										<title>1994 - 1996 Corvette:  Service Bulletin:  Door Trim Arm Rest Lid Hard to Open or Close, Hinge Binding (Replace Hinge)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-window-assist-rods-664.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Window Assist Rods</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-window-assist-rods-664.html</link>
