										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-remote-keyless-entry-system-rke-and-or-low-tire-pressure-monitoring-system-inoperative-374.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-remote-keyless-entry-system-rke-and-or-low-tire-pressure-monitoring-system-inoperative-374.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-tires-slipping-on-wheels-495.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Tires Slipping on Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-tires-slipping-on-wheels-495.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</guid>
										<title>1981 - 1990 Corvette:  Service Bulletin:  Procedures on Scuff/Scratch Removal from Clear Coat on Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-recommended-wheel-nut-bolt-torque-specifications-368.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - Recommended Wheel Nut/Bolt Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-recommended-wheel-nut-bolt-torque-specifications-368.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-low-tire-pressure-message-on-dic-slow-air-loss-370.html</guid>
										<title>2000 Corvette: Service Bulletin: Low Tire Pressure Message on DIC, Slow Air Loss</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-low-tire-pressure-message-on-dic-slow-air-loss-370.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-product-safety-campaign-product-safety-campaign-no-88c09-possible-missing-wheel-weld-1243.html</guid>
										<title>1988 Corvette:  Product Safety Campaign:  Product Safety Campaign No. 88C09 - Possible Missing Wheel Weld</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-product-safety-campaign-product-safety-campaign-no-88c09-possible-missing-wheel-weld-1243.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-info-proper-tire-pressure-369.html</guid>
										<title>2001 Corvette: Service Bulletin: Info - Proper Tire Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-info-proper-tire-pressure-369.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-ltpws-light-on-tire-pressure-is-correct-493.html</guid>
										<title>1990 Corvette: Service Bulletin: &quot;Service LTPWS&quot; Light On, Tire Pressure is Correct</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-ltpws-light-on-tire-pressure-is-correct-493.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-service-bulletin-info-wheel-pressure-sensors-unable-to-be-reprogrammed-after-tire-replacement-305.html</guid>
										<title>2001 - 2004 Corvette: Service Bulletin: Info - Wheel Pressure Sensors Unable to be Reprogrammed after Tire Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-service-bulletin-info-wheel-pressure-sensors-unable-to-be-reprogrammed-after-tire-replacement-305.html</link>
