<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Hard Start on Hot Restart / Increased Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-service-program-483.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-service-program-483.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Transmission Exchange Program 6 Speed M/T (ML9)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-no-start-condition-replace-starter-485.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: No Start Condition (Replace Starter)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-no-start-condition-replace-starter-485.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</guid>
										<title>1990 Corvette ZR-1: Service Bulletin: Leaking Radiator Hose Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</guid>
										<title>1990 Corvette: Service Bulletin: L98 and LT5: Revised Air Conditioning Control Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</link>
