<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-zr-1-characteristics-of-a-l-dunn-cylinder-heads-478.html</guid>
										<title>1994 - 1995 Corvette ZR-1: Characteristics of A.L. Dunn Cylinder Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-zr-1-characteristics-of-a-l-dunn-cylinder-heads-478.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Diagnosing Low Tire Pressure Warning System Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</guid>
										<title>1990 Corvette: Recall: Instrument Panel Wire Abrasion - Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Body Emblem Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-differences-between-first-and-second-generation-zf-6-speed-transmissions-605.html</guid>
										<title>1989 - 1996 Corvette: Differences between First and Second Generation ZF 6-Speed Transmissions</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Transmission Exchange Program 6 Speed M/T (ML9)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</guid>
										<title>1988 - 1990 Corvette: Service Bulletin: Power Steering Shudder / Groan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Noise - Install Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</guid>
										<title>1990 Corvette: Service Bulletin: L98 and LT5: Revised Air Conditioning Control Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</link>
