										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</guid>
										<title>1991 Corvette: Service Bulletin: Loss of Heat/Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Body Emblem Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-cast-aluminum-wheel-porosity-repair-82.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Cast Aluminum Wheel Porosity Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-cast-aluminum-wheel-porosity-repair-82.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</guid>
										<title>1990 Corvette ZR-1: Service Bulletin: Leaking Radiator Hose Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</guid>
										<title>1988 - 1990 Corvette: Service Bulletin: Power Steering Shudder / Groan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Diagnosing Low Tire Pressure Warning System Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</guid>
										<title>1981 - 1990 Corvette:  Service Bulletin:  Procedures on Scuff/Scratch Removal from Clear Coat on Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-zr-1-characteristics-of-a-l-dunn-cylinder-heads-478.html</guid>
										<title>1994 - 1995 Corvette ZR-1: Characteristics of A.L. Dunn Cylinder Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-zr-1-characteristics-of-a-l-dunn-cylinder-heads-478.html</link>
