										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-bulletin-left-fuel-tank-to-underbody-contact-rattle-noise-456.html</guid>
										<title>1999 Corvette: Service Bulletin: Left Fuel Tank to Underbody Contact/Rattle Noise</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</guid>
										<title>1998 - 2003 Corvette Convertible: Trunk Door on Convertible Won`t Open All The Way</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</guid>
										<title>1997+ Corvette: Technical Article: Corvette Converts Floor Panels, Wheelhousings From Glass To Chopped Carbon</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</guid>
										<title>1997 - 2001 Corvette: Service Bulletin: Park/Neutral Position Switch Connector Cannot Be Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</guid>
										<title>1997 - 2002 Corvette: GM TechLink: Hydraulic Clutch Fluid Discoloration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
