<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-convertible-top-operating-instructions-1292.html</guid>
										<title>1998 - 2004 Corvette:  Convertible Top Operating Instructions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-convertible-top-operating-instructions-1292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-bulletin-left-fuel-tank-to-underbody-contact-rattle-noise-456.html</guid>
										<title>1999 Corvette: Service Bulletin: Left Fuel Tank to Underbody Contact/Rattle Noise</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</guid>
										<title>1997 Corvette: Service Bulletin: Hatch Will Not Pop Up When Activated in Cold Weather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Loose or Missing Headlamp Door Bezel Plug</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Front Fender to Door Fit/Appearance (Install Retainer)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</guid>
										<title>1998 Corvette:  Service News:  Corvette Convertible Top Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</guid>
										<title>2000 Corvette: Service Bulletin: Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</link>
