<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</guid>
										<title>1998 Corvette:  Service News:  Corvette Convertible Top Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Waterleak Above Door Glass (Reseal Blowout Clip)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</guid>
										<title>1998 - 2003 Corvette Convertible: Trunk Door on Convertible Won`t Open All The Way</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</guid>
										<title>1998 - 2003 Corvette Convertible: Prevention of Convertible Top From Rubbing Against the Paint Behind the Plastic Strip</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: General Waterleak Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</link>
