<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-bulletin-left-fuel-tank-to-underbody-contact-rattle-noise-456.html</guid>
										<title>1999 Corvette: Service Bulletin: Left Fuel Tank to Underbody Contact/Rattle Noise</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-paint-wear-through-at-fifth-bow-replace-seal-460.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Paint Wear Through at Fifth Bow (Replace Seal)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-paint-wear-through-at-fifth-bow-replace-seal-460.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Discoloration or Staining of Plenum (Cowl) Air Inlet Screen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: General Waterleak Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</guid>
										<title>Procedure for Replacing the Reveal Moldings Over Side Windows on a 2001 - 2004 Corvette Z06</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</guid>
										<title>1997 - 2004 Corvette: Press Release: Not a Lightweight at All: New Composite from GM Is Stiff Enough for Structure, Resistant to Heat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</link>
