<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</guid>
										<title>1998 - 2003 Corvette Convertible: Prevention of Convertible Top From Rubbing Against the Paint Behind the Plastic Strip</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Loose or Missing Headlamp Door Bezel Plug</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-hiss-type-noise-coming-from-weatherstrip-when-closing-right-or-left-door-472.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Hiss Type Noise Coming From Weatherstrip When Closing Right or Left Door</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-hiss-type-noise-coming-from-weatherstrip-when-closing-right-or-left-door-472.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</guid>
										<title>1998 Corvette:  Service News:  Corvette Convertible Top Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</link>
