										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Door Handles on White Painted Cars Turning Yellow</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</guid>
										<title>1998 - 2003 Corvette Convertible: Trunk Door on Convertible Won`t Open All The Way</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Loose or Missing Headlamp Door Bezel Plug</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Waterleak Above Door Glass (Reseal Blowout Clip)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</guid>
										<title>1997 - 2000 Corvette: Chevrolet Pro Service News:  Corvette Windnoise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</link>
