<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Clicking Noise Coming From Folding Top</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</guid>
										<title>1997 - 2000 Corvette: Chevrolet Pro Service News:  Corvette Windnoise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-bulletin-left-fuel-tank-to-underbody-contact-rattle-noise-456.html</guid>
										<title>1999 Corvette: Service Bulletin: Left Fuel Tank to Underbody Contact/Rattle Noise</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Tonneau Cover Makes Noise When Going Over Bumps</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Front Fender to Door Fit/Appearance (Install Retainer)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</guid>
										<title>1997 - 2004 Corvette: Press Release: Not a Lightweight at All: New Composite from GM Is Stiff Enough for Structure, Resistant to Heat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: General Waterleak Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</guid>
										<title>1998 - 2003 Corvette Convertible: Prevention of Convertible Top From Rubbing Against the Paint Behind the Plastic Strip</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</link>
