										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-higher-than-expected-oil-consumption-308.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Higher Than Expected Oil Consumption</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-z06-alignment-specifications-309.html</guid>
										<title>2001 Corvette Z06: Alignment Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-z06-alignment-specifications-309.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</guid>
										<title>1997 Corvette: Service Bulletin: Hatch Will Not Pop Up When Activated in Cold Weather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Clicking Noise Coming From Folding Top</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-z06-locating-z06-wheel-touch-up-paint-306.html</guid>
										<title>2001 - 2004 Corvette Z06: Locating Z06 Wheel Touch-Up Paint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-z06-locating-z06-wheel-touch-up-paint-306.html</link>
