<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</guid>
										<title>1984 Corvette: Recall: Front Brake Caliper Bracket Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</guid>
										<title>2000 Corvette: ABS Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html</guid>
										<title>2001 - 2002 Corvette: Service Bulletin: Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</guid>
										<title>1986 Corvette:  Recall Notice:  Anti-Skid Brake System Master Cylinder Center Valve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-stainless-steel-brake-lines-451.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-stainless-steel-brake-lines-451.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html</guid>
										<title>1981 - 1990 Corvette: Service Bulletin: Brake Rotor Refinish Parts Ordering Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: How to Replace Your Front Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-incomplete-brake-pedal-return-449.html</guid>
										<title>2001 Corvette: Service Bulletin: Incomplete Brake Pedal Return</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-incomplete-brake-pedal-return-449.html</link>
