<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-incomplete-brake-pedal-return-449.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</guid>
										<title>1995 - 2002 Corvette: Service Bulletin: Warranty Admin. - Brake Rotor Warranty Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-stainless-steel-brake-lines-451.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-stainless-steel-brake-lines-451.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html</guid>
										<title>2001 - 2002 Corvette: Service Bulletin: Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</guid>
										<title>2000 Corvette: ABS Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</guid>
										<title>1997 - 2011 Corvette:  GM TechLink:  Aftermarket Braided Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</link>
