<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</guid>
										<title>1997 - 2004 Corvette:  T-56 Borg Warner Transmission Repair Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</guid>
										<title>1995 - 1996 Corvette: Service Bulletin: Delayed Engagement (Replace Pump Cover Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Click/Whine in 3rd/4th Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</guid>
										<title>1984 - 1989 Corvette:  Service Bulletin: Steering Gear Intermediate Shaft Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</guid>
										<title>1994 Corvette: Service Bulletin: Garage Shift Delay Engagement (New Garage Shift Package)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</link>
