										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</guid>
										<title>1994 Corvette: Service Bulletin: Garage Shift Delay Engagement (New Garage Shift Package)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Click/Whine in 3rd/4th Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</guid>
										<title>1995 - 1996  Corvette: Service Bulletin: Transmission Fluid Leak From Pump Body</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</guid>
										<title>1984 - 1985 Corvette:  Service Bulletin:  Noise in Direct Drive 4-Speed Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</guid>
										<title>2005 Corvette: Service Bulletin: Mis-Machined Transmission Countershaft Snap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission Delayed Engagement From PARK to DRIVE or PARK to REVERSE (Reprogram Transmission Control Module (TCM))</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-new-low-and-reverse-clutch-support-selective-plate-dimensions-599.html</guid>
										<title>1990 Corvette: Service Bulletin: New Low and Reverse Clutch Support Selective Plate Dimensions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-new-low-and-reverse-clutch-support-selective-plate-dimensions-599.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission (RPO MYC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: No/Delayed Reverse When Cold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</link>
