<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</guid>
										<title>1997 - 2003 Corvette: GM TechLink: Transmission Stuck in Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2006-corvette-service-bulletin-intermittent-neutral-from-a-stop-or-2-3-shift-433.html</guid>
										<title>1999 - 2006 Corvette: Service Bulletin: Intermittent Neutral from a Stop or 2-3 Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2006-corvette-service-bulletin-intermittent-neutral-from-a-stop-or-2-3-shift-433.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</guid>
										<title>1997 - 1998 Corvette:  Service News:  Automatic Transmission Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</guid>
										<title>1997 - 2002 Corvette: GM TechLink: Hydraulic Clutch Fluid Discoloration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission (RPO MYC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
