<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2006-corvette-service-bulletin-intermittent-neutral-from-a-stop-or-2-3-shift-433.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</guid>
										<title>1997 - 2001 Corvette: Service Bulletin: Park/Neutral Position Switch Connector Cannot Be Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Automatic Transmission Service Procedure Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</guid>
										<title>1997 - 2004 Corvette:  T-56 Borg Warner Transmission Repair Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</guid>
										<title>1997 - 2003 Corvette: GM TechLink: Transmission Stuck in Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission (RPO MYC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</guid>
										<title>1997 - 2002 Corvette: GM TechLink: Hydraulic Clutch Fluid Discoloration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
