<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</guid>
										<title>2009 Corvette:  Pairing Key Fob to Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-erratic-fuel-gauge-readings-415.html</guid>
										<title>1997 Corvette: Service Bulletin: Erratic Fuel Gauge Readings</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-diagnostic-trouble-codes-225.html</guid>
										<title>2004 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-diagnostic-trouble-codes-225.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</guid>
										<title>2002 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</guid>
										<title>2000 Corvette:  Electrical Features Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-special-policy-adjustment-electronic-column-lock-system-158.html</guid>
										<title>1997 - 2004 Corvette: Recall: Special Policy Adjustment  - Electronic Column Lock System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-special-policy-adjustment-electronic-column-lock-system-158.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</guid>
										<title>1997 Corvette: Service Bulletin: Various Driveability Issues (Repair/Secure Wire Harness at PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-pcm-reprogramming-and-data-line-diagnosis-using-j-44236-a-427.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Info - PCM Reprogramming and Data Line Diagnosis using J 44236-A</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-pcm-reprogramming-and-data-line-diagnosis-using-j-44236-a-427.html</link>
