<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</guid>
										<title>2003 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</guid>
										<title>1999 - 2013 Corvette: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-recall-electronic-column-lock-412.html</guid>
										<title>1998 - 2000 Corvette: Recall: Electronic Column Lock</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-recall-electronic-column-lock-412.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</guid>
										<title>2009 Corvette:  Pairing Key Fob to Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</link>
