<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-1961-convertible-top-adjustments-41.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-effect-of-solvents-on-lucite-acrylic-lacquer-finishes-997.html</guid>
										<title>1956 - 1957 Corvette:  Service Bulletin:  Effect of Solvents on Lucite Acrylic Lacquer Finishes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-effect-of-solvents-on-lucite-acrylic-lacquer-finishes-997.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-overlapping-wiper-blades-1001.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Overlapping Wiper Blades</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-overlapping-wiper-blades-1001.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-effect-of-solvents-on-lucite-acrylic-lacquer-finish-793.html</guid>
										<title>1957 Corvette: Service Bulletin: Effect of Solvents on Lucite Acrylic Lacquer Finish</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-effect-of-solvents-on-lucite-acrylic-lacquer-finish-793.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</guid>
										<title>1958 Corvette: Service Bulletin: Nylon Headlamp Adjusting Screw Bracket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Front and Rear Door Glass Loose in Run Channels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-corvette-body-repair-175.html</guid>
										<title>1953 Corvette: Service Bulletin: Corvette Body Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-corvette-body-repair-175.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-grille-vibration-890.html</guid>
										<title>1961 Corvette:  Service Bulletin:  Corvette Grille Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-grille-vibration-890.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-zone-letter-fitting-hard-top-on-corvettes-794.html</guid>
										<title>1957 Corvette: Zone Letter: Fitting Hard Top on Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-zone-letter-fitting-hard-top-on-corvettes-794.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1960-corvette-chevrolet-central-office-letter-substitution-for-1961-corvette-hardtop-assemblies-on-prior-models-795.html</guid>
										<title>1956 - 1960 Corvette: Chevrolet Central Office Letter: Substitution for 1961 Corvette Hardtop Assemblies on Prior Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1960-corvette-chevrolet-central-office-letter-substitution-for-1961-corvette-hardtop-assemblies-on-prior-models-795.html</link>
