<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-power-antenna-not-working-properly-or-is-completely-inoperative-409.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</guid>
										<title>1997 - 1998, 2000 Corvette: Service Bulletin: Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</guid>
										<title>2003 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-electronic-column-lock-system-418.html</guid>
										<title>1997 - 2004 Corvette: Recall: Electronic Column Lock System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-electronic-column-lock-system-418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Inoperative Remote Keyless Entry System and/or Tire Pressure Monitor System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-tech-left-headlamp-door-does-not-stay-closed-408.html</guid>
										<title>2000 Corvette: Service Bulletin: Tech - Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-tech-left-headlamp-door-does-not-stay-closed-408.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-no-start-condition-non-functional-pcm-after-reprogramming-422.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: No Start Condition, Non-Functional PCM After Reprogramming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-no-start-condition-non-functional-pcm-after-reprogramming-422.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</guid>
										<title>1997 Corvette: Product Campaign: PCM Calibration Reflash</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</link>
