<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Diagnostics and Procedures to Prevent Codes 16 and 26 Due to Corrosion Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</guid>
										<title>1998 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-411.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-411.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</guid>
										<title>1997 - 2000 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-power-antenna-not-working-properly-or-is-completely-inoperative-409.html</guid>
										<title>2000 Corvette: Service Bulletin: Power Antenna Not Working Properly or is Completely Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-power-antenna-not-working-properly-or-is-completely-inoperative-409.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-pcm-reprogramming-and-data-line-diagnosis-using-j-44236-a-427.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Info - PCM Reprogramming and Data Line Diagnosis using J 44236-A</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-pcm-reprogramming-and-data-line-diagnosis-using-j-44236-a-427.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
