<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-accessory-drive-squeak-replace-idler-pulley-401.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Accessory Drive Squeak (Replace Idler Pulley)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-accessory-drive-squeak-replace-idler-pulley-401.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Belt Rumble Noise at Low Idle Speeds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-reduced-engine-power-message-along-with-partic-powertrain-402.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Reduced Engine Power Message Along With Partic. Powertrain</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-reduced-engine-power-message-along-with-partic-powertrain-402.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: SMU - Revised Side Cover and Gasket Replacement (RH)/Differential Carrier Cover and Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</guid>
										<title>2004 Corvette:  Campaign Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</link>
