<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</guid>
										<title>2004 Corvette: GM TechLink: Oil Pump to Case Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Belt Rumble Noise at Low Idle Speeds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-corvette-engine-low-coolant-mil-1048.html</guid>
										<title>1997 - 1998 Corvette:  Service News:  Corvette Engine Low Coolant MIL</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-corvette-engine-low-coolant-mil-1048.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</guid>
										<title>1997 - 2004 Corvette:  Technical Article: The Millenium Motor: Inside C5`s LS1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Coolant Leak at Cup Plugs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Needle Bearings Found In Oil Pan (Replace Rocker Arms)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</link>
