										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Needle Bearings Found In Oil Pan (Replace Rocker Arms)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</guid>
										<title>2004 Corvette: GM TechLink: Oil Pump to Case Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Fuel Tank System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</guid>
										<title>1997 - 1999: Service Bulletin: Engine Low Coolant Light Comes On (Inspect Rad. Surge Tank, Replace/Reposition)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</guid>
										<title>Procedure for Replacing the Reveal Moldings Over Side Windows on a 2001 - 2004 Corvette Z06</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</link>
