										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</guid>
										<title>1997 - 1998, 2000 Corvette: Service Bulletin: Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</guid>
										<title>1997 Corvette: Product Campaign: PCM Calibration Reflash</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Needle Bearings Found In Oil Pan (Replace Rocker Arms)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-higher-than-expected-oil-consumption-308.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Higher Than Expected Oil Consumption</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</guid>
										<title>1999 - 2013 Corvette: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</guid>
										<title>2004 - 2005 Corvette: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Fuel Pump Noise Coming From Fuel Pump/Tank (Replace Fuel Pump Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</guid>
										<title>1998 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Diagnostics and Procedures to Prevent Codes 16 and 26 Due to Corrosion Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</link>
