<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Intermittent Accessory Drive Rumble During Garage Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</guid>
										<title>1997 - 2004 Corvette:  Technical Article: The Millenium Motor: Inside C5`s LS1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</guid>
										<title>1997+ Corvette: Technical Article: Corvette Converts Floor Panels, Wheelhousings From Glass To Chopped Carbon</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</guid>
										<title>Procedure for Replacing the Reveal Moldings Over Side Windows on a 2001 - 2004 Corvette Z06</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-higher-than-expected-oil-consumption-308.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Higher Than Expected Oil Consumption</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-z06-recall-emission-label-error-312.html</guid>
										<title>2001 Corvette Z06: Recall: Emission Label Error</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-z06-recall-emission-label-error-312.html</link>
