										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Power Antenna Will Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</guid>
										<title>1994 - 1996 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</guid>
										<title>1995 Corvette: Ignition: No-Start Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-engine-removal-procedures-545.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Engine Removal Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-engine-removal-procedures-545.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-radio-may-lose-some-functions-inspect-radio-fuse-567.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Radio May Lose Some Functions, Inspect Radio Fuse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-radio-may-lose-some-functions-inspect-radio-fuse-567.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Rebuilding the LT1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</guid>
										<title>1989 Corvette: Service Bulletin: Bose Amplifiers Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</guid>
										<title>1990 Corvette: Service Bulletin: Radio May Lose Some Functions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-new-delco-loc-ii-setting-procedure-and-information-571.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: New Delco-Loc II Setting Procedure and Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-new-delco-loc-ii-setting-procedure-and-information-571.html</link>
