<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Fuel Tank System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Belt Rumble Noise at Low Idle Speeds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Intermittent Accessory Drive Rumble During Garage Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</guid>
										<title>2001 Corvette: Service Bulletin: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</guid>
										<title>2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-output-shaft-seal-replacement-procedure-397.html</guid>
										<title>1997 - 2003 Corvette: Service Manual Update: Revised Output Shaft Seal Replacement Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-output-shaft-seal-replacement-procedure-397.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</guid>
										<title>2004 Corvette: GM TechLink: Oil Pump to Case Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</link>
