<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Intermittent Accessory Drive Rumble During Garage Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</guid>
										<title>2004 Corvette:  Campaign Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</guid>
										<title>2005 Corvette: GM TechLink: Gasoline Engine Oil Requirements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</guid>
										<title>1997 - 2004 Corvette:  Technical Article: The Millenium Motor: Inside C5`s LS1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Coolant Leak at Cup Plugs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</guid>
										<title>1997 - 1999: Service Bulletin: Engine Low Coolant Light Comes On (Inspect Rad. Surge Tank, Replace/Reposition)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-ses-lamp-setting-a-p0106-and-or-p0506-1315.html</guid>
										<title>2017 Corvette:  Service Bulletin: SES Lamp Setting A P0106 And/or P0506</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-ses-lamp-setting-a-p0106-and-or-p0506-1315.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-axle-vent-noise-329.html</guid>
										<title>2005 Corvette: GM TechLink: Axle Vent Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-axle-vent-noise-329.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Fuel Tank System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</link>
