<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Belt Rumble Noise at Low Idle Speeds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-fluid-leak-at-rear-axle-replace-left-differential-side-cover-0-ring-and-left-axle-shaft-seal-add-sealant-to-side-cover-flange-404.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Fluid Leak at Rear Axle (Replace Left Differential Side Cover 0-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-fluid-leak-at-rear-axle-replace-left-differential-side-cover-0-ring-and-left-axle-shaft-seal-add-sealant-to-side-cover-flange-404.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</guid>
										<title>2004 Corvette:  Campaign Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</guid>
										<title>2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</guid>
										<title>2001 Corvette: Service Bulletin: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: SMU - Revised Side Cover and Gasket Replacement (RH)/Differential Carrier Cover and Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</link>
