<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-378.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-seatbelt-retractor-377.html</guid>
										<title>2004 Corvette: GM TechLink: Seatbelt Retractor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-seatbelt-retractor-377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-recall-lap-belt-webbing-twisted-381.html</guid>
										<title>1997 - 2000 Corvette: Recall: Lap Belt Webbing Twisted</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-recall-lap-belt-webbing-twisted-381.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-door-rattle-with-moderate-to-high-audio-system-volume-380.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Door Rattle with Moderate to High Audio System Volume</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-door-rattle-with-moderate-to-high-audio-system-volume-380.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-news-corvette-telescoping-steering-wheel-travel-883.html</guid>
										<title>1999 Corvette: Service News: Corvette Telescoping Steering Wheel Travel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-news-corvette-telescoping-steering-wheel-travel-883.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-smu-revised-seatback-cover-removal-procedure-383.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: SMU - Revised Seatback Cover Removal Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-smu-revised-seatback-cover-removal-procedure-383.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Instrument Panel Cluster Function and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-driver-seat-movement-during-acceleration-and-braking-replace-adjuster-assembly-379.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Driver Seat Movement During Acceleration and Braking (Replace Adjuster Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-driver-seat-movement-during-acceleration-and-braking-replace-adjuster-assembly-379.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-seat-back-twisting-resynchronize-seat-back-recliner-219.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Seat Back Twisting (Resynchronize Seat Back Recliner)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-seat-back-twisting-resynchronize-seat-back-recliner-219.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-squeak-type-noise-from-leather-shift-boot-when-shifting-gears-382.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Squeak Type Noise From Leather Shift Boot when Shifting Gears</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-squeak-type-noise-from-leather-shift-boot-when-shifting-gears-382.html</link>
