										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-info-proper-tire-pressure-369.html</guid>
										<title>2001 Corvette: Service Bulletin: Info - Proper Tire Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-info-proper-tire-pressure-369.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-tire-tips-321.html</guid>
										<title>2005 - 2013 Corvette: GM TechLink: Tire Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-tire-tips-321.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-wheel-touch-up-paint-373.html</guid>
										<title>1997 - 1999 Corvette: Wheel Touch-Up Paint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-wheel-touch-up-paint-373.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-c4-c5-corvette-emt-run-flat-tire-servicing-492.html</guid>
										<title>Technical Article: C4/C5 Corvette EMT Run-Flat Tire Servicing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-recommended-wheel-nut-bolt-torque-specifications-368.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - Recommended Wheel Nut/Bolt Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-recommended-wheel-nut-bolt-torque-specifications-368.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-service-bulletin-tire-vibration-at-speeds-above-70-mph-59.html</guid>
										<title>2009 - 2011 Corvette:  Service Bulletin:  Tire Vibration at Speeds Above 70 mph</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-service-bulletin-tire-vibration-at-speeds-above-70-mph-59.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-tire-vibration-64.html</guid>
										<title>2009 - 2011 Corvette:  GM TechLink: Tire Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-tire-vibration-64.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-info-refinishing-aluminum-wheels-367.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Info - Refinishing Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-info-refinishing-aluminum-wheels-367.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-tire-pressure-monitoring-system-information-375.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Tire Pressure Monitoring System Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-tire-pressure-monitoring-system-information-375.html</link>
