<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</guid>
										<title>1997 - 2004 Corvette: Press Release: Not a Lightweight at All: New Composite from GM Is Stiff Enough for Structure, Resistant to Heat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Front Fender to Door Fit/Appearance (Install Retainer)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Door Handles on White Painted Cars Turning Yellow</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</guid>
										<title>2000 Corvette: Service Bulletin: Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-z06-alignment-specifications-309.html</guid>
										<title>2001 Corvette Z06: Alignment Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-z06-alignment-specifications-309.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Discoloration or Staining of Plenum (Cowl) Air Inlet Screen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-z06-locating-replacement-fix-a-flat-for-z06-tires-307.html</guid>
										<title>2001 - 2004 Corvette Z06: Locating Replacement &quot;Fix-A-Flat&quot; for Z06 Tires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-z06-locating-replacement-fix-a-flat-for-z06-tires-307.html</link>
