<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-bulletin-left-fuel-tank-to-underbody-contact-rattle-noise-456.html</guid>
										<title>1999 Corvette: Service Bulletin: Left Fuel Tank to Underbody Contact/Rattle Noise</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</guid>
										<title>1997+ Corvette: Technical Article: Corvette Converts Floor Panels, Wheelhousings From Glass To Chopped Carbon</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Door Handles on White Painted Cars Turning Yellow</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Front Fender to Door Fit/Appearance (Install Retainer)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</link>
