<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-hydraulic-brake-line-leak-359.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-gm-techlink-brake-pads-356.html</guid>
										<title>2006 Corvette: GM TechLink: Brake Pads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-gm-techlink-brake-pads-356.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-information-on-visual-brake-rotor-surface-cracking-201.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Information on Visual Brake Rotor Surface Cracking</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-information-on-visual-brake-rotor-surface-cracking-201.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</guid>
										<title>1997 - 2011 Corvette:  GM TechLink:  Aftermarket Braided Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-04086-rear-brake-lining-routing-358.html</guid>
										<title>2005 Corvette: Recall: 04086 -- Rear Brake Lining Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-04086-rear-brake-lining-routing-358.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-cross-drilled-rotors-357.html</guid>
										<title>2005 Corvette: GM TechLink: Cross-Drilled Rotors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-cross-drilled-rotors-357.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</guid>
										<title>2009 - 2017 Corvette: Service Bulletin: #PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</link>
