										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin:  Rear Axle Clunk and/or Chatter Type Noise on Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</guid>
										<title>2003 Corvette:  Technical Article:  Magnetic Selective Ride Control - First Ride</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2000-corvette-service-bulletin-smu-deletion-of-variable-effort-steering-description-447.html</guid>
										<title>1999 - 2000 Corvette: Service Bulletin: SMU - Deletion of Variable Effort Steering Description</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2000-corvette-service-bulletin-smu-deletion-of-variable-effort-steering-description-447.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-corvette-crossmember-design-and-manufacturing-797.html</guid>
										<title>1997 - 2004 Corvette: Technical Article: Corvette Crossmember Design and Manufacturing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-drive-axle-boot-pliers-100.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Drive Axle Boot Pliers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-drive-axle-boot-pliers-100.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-recall-notice-rear-suspension-tie-rod-assembly-1154.html</guid>
										<title>1997 Corvette:  Recall Notice:  Rear Suspension Tie Rod Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-recall-notice-rear-suspension-tie-rod-assembly-1154.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-rear-wheel-drive-shaft-nut-torque-specification-requirements-and-information-on-replacement-shafts-for-service-317.html</guid>
										<title>2005 - 2006 Corvette: Rear Wheel Drive Shaft Nut Torque Specification Requirements and Information on Replacement Shafts for Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-rear-wheel-drive-shaft-nut-torque-specification-requirements-and-information-on-replacement-shafts-for-service-317.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - New Vehicle Preparation for Magnetic Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</guid>
										<title>1998 - 2004 Corvette:  Press Release: Active Handling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</link>
