<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-clutch-pedal-does-not-return-to-up-position-during-shifts-at-high-engine-rpms-353.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</guid>
										<title>2008 Corvette: Service Information: Hydra-Matic 6L80 Six-Speed Automatic Car &amp; Truck Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</guid>
										<title>2005 - 2007 Corvette:  Service Bulletin:  Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</guid>
										<title>2005 Corvette: Service Bulletin: Mis-Machined Transmission Countershaft Snap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</guid>
										<title>2006 - 2008 Corvette: GM TechLink: 6L80 or 6L90 Automatic Transmission Shift Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission Delayed Engagement From PARK to DRIVE or PARK to REVERSE (Reprogram Transmission Control Module (TCM))</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-clutch-hydraulic-system-new-service-owner-maintenance-information-58.html</guid>
										<title>2005 - 2009 Corvette:  Service Bulletin: Clutch Hydraulic System -- New Service/Owner Maintenance Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-clutch-hydraulic-system-new-service-owner-maintenance-information-58.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</guid>
										<title>2007 Corvette: Service Bulletin: Information Regarding Automatic Transmission Shift Lock Control Function</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</guid>
										<title>2005 Corvette: Service Bulletin: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</link>
