										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</guid>
										<title>2006 Corvette: Electrical Schematic: Satellite Radio Circuit System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-fob-conditions-104.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Fob Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-fob-conditions-104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</guid>
										<title>2006 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</guid>
										<title>2009 Corvette: Service Campaign: OnStar System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Rear Window Defogger Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</link>
