<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink: Trip Odometer Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-changer-parked-message-cd-99.html</guid>
										<title>2008 Corvette: GM TechLink: &quot;Changer Parked&quot; Message (CD)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-changer-parked-message-cd-99.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-safety-recall-number-13149-low-beam-headlamps-inoperative-1097.html</guid>
										<title>2005 - 2007 Corvette:  Safety Recall:  Number 13149, Low-Beam Headlamps Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-safety-recall-number-13149-low-beam-headlamps-inoperative-1097.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-diagnostic-trouble-codes-221.html</guid>
										<title>2005 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-diagnostic-trouble-codes-221.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Door Handle Release Button</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-instrument-panel-i-p-body-and-general-wiring-harness-repair-199.html</guid>
										<title>2007 Corvette: Service Bulletin: Instrument Panel (I/P), Body and General Wiring Harness Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-instrument-panel-i-p-body-and-general-wiring-harness-repair-199.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Starting - Charging System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-poor-and-or-no-radio-reception-intermittent-static-on-fm-with-navigational-radio-system-update-radio-software-340.html</guid>
										<title>2005 Corvette: Service Bulletin: Poor and/or No Radio Reception, Intermittent Static on FM with Navigational Radio System (Update Radio Software)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-poor-and-or-no-radio-reception-intermittent-static-on-fm-with-navigational-radio-system-update-radio-software-340.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</guid>
										<title>2005 - 2012 Corvette: GM TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</link>
